WZ 2 config - mouse movement not recognized/not locked
  • WZ 2 config - mouse movement not recognized/not locked
    Tried to use rewasd config for WZ "For Keyboard & Mouse.rewasd", but failed with a mouse movement.
    Everything works except of the mouse movement. Using laptop and wireless mouse (HP comfort grip). Keyboard works as expected, but mouse movement is not locked once you activate the config, even though mouse buttons are locked and working in WZ as expected. Tried to re-initialize and tweak some different settings, but no luck. Any advice on this one ?
    Please check the License (an icon with a "crown" at the top right). Go to Advanced mapping feature to see if it is active now (has Trial days left shown in a title).
      Thanks, I found it after one hour of investigation. It is not really clear when you download it or install, because everything works expect of the mouse movement.
      Nevertheless, received different gaming experience than on a mouse and keyboard. WZ 2.0 AA just sticks to an enemy, that's amazing and literally legal aimbot to use, gonna buy a license.
      Topic can be closed.
        We are glad that your issue has been resolved.
        Always happy to help!​
