Toggle macro for x amount of time
  • Toggle macro for x amount of time
    Is it possible to toggle (continues playback) a macro for x amount of time, lets say 1 min. After that it should turn it self off. Trying to avoid making a 1 minute long script.
    Thanks in advance
    Unfortunately, you can't set continued playback for x amount of time.
    As an alternative, you can set the amount of iteration for your combo:
