Is it possible to make a combo so it can't be interrupted?
  • Is it possible to make a combo so it can't be interrupted?
    Hi, i use REWASD to "YY Macro" and am wondering it it's possible to make a combo so it can't be interrupted?
    I set it to press the change weapon button twice, then i turbo that but its a tossup as to if it will bring the wrong weapon out, wonder if there's a way to ensure the combo always plays through till the end?
    cheers
    The [Turbo] option is what makes this [Combo] stop the moment you release the key. Disable it, so the [Combo] would always play to the end.
      Damn, I was hoping to be able to set it so the combo played all the way through will turbo enabled. Oh well, thanks for the info
        I'll make a suggestion in the section to add the feature, thanks again
