Mapping keyboard to controller: how do I map two controller buttons at the same time? For example, to run, I have to hold R2 and then the stick direction I want to run. I've only been able to map one button at a time. New to reWASD.
Mapping for two buttons on the controller at the same time.
thanks. It's helpful to meOriginally Posted by Shion View PostYou would need to remap the key to a [Combo] of [R2] and left stick. Check these articles for details:Last edited by limbictomatoe; 21.11.2023, 15:26.
Thanks, that solves the problem of how to activate those at the same time, but how do I change it into an input. I meant that the controller is what I'm using to emulate a keyboard. In the game, double-pressing the A key makes you run to the left, and I want that to happen when I hold R2 and move the stick to the left.Originally Posted by Shion View PostYou would need to remap the key to a [Combo] of [R2] and left stick. Check these articles for details:
In that case, you should set up [Shortcuts] of [R2] and every direction and remap them to a [Combo] of the corresponding keyboard key twice, with a pause node of about a minute between the second press/release node, and enable the [Turbo] option for that mapping.
For example, the [Combo] for [R2]+[Left Stick Up] should be: [W pressed] > [W released] > [W pressed] > [Pause 60000ms] > [W released].
