Remapping MK to use Controller Aim Assist
  • Remapping MK to use Controller Aim Assist
    I play MK on PC. I'd like to purchase ReWASD to use MK with the Controller setting to enable aim assist. Will this product allow me to use MK as Controller? Thanks
    First, I'll have to warn you that reWASD does not provide aim assist. The game does, when it detects that player uses controller only. reWASD doesn't have an effect on aim assist
    1. Make sure you have [Advanced mapping] feature, as it is required to remap mouse to a stick of our virtual controller.
    2. If necessary, initialize your mouse and keyboard devices. You can use [Device detection] to know who is who if device names don't state that clearly (https://help.rewasd.com/interface/device-detection.html)
    3. Group up your keyboard and mouse devices. In case of problems check case #24 here: https://help.rewasd.com/faq/troubleshooting.html#24
    4. Look for fitting config at our Community page here and import it into reWASD: https://www.rewasd.com/community
    5. Make sure that a button to "unlock" mouse and keyboard is set up in the config (it's [LWin] key at [Shift #4] by default). If it is not, check this article on how to set it up: https://help.rewasd.com/faq/unmappedmouse.html
    6. Hit [Apply] button. Your mouse will "freeze". Use the "unlock" key from step #4 to unlock the mouse and start the game. In case of emergency you can use [CTRL]+[ALT]+[DEL] shortcut to disable remap entirely.
