As the title suggests, I want to emulate steering wheel rotation position using left stick on my XBOX One Elite Series 2 controller. Is this possible?
A bit more detailed explanation. I've been looking for a gamepad like controller that can emulate racing wheel. What comes to mind is PSone's 3rd party controller made by NAMCO, a JOGCON or a NEGCON. Sadly, there's nothing like that for modern consoles or PC. So, as an alternative I'm trying to make a left stick rotation to mimic racing wheel rotation, so if I push my left stick at 12 o'clock, then the wheel will be "grabbed" and be positioned at 12 o'clock. If I rotate my left stick to 10 o'clock position, then the wheel should move to 10 o'clock position. If I let go of the stick, the wheel should return to center. This degree of position mapping should be adjustable (be it 1:1, or 900 degrees click to click, etc), but for explanation purposes, this should suffice. Is this achievable using reWASD?
Thank you!
Thank you!
