Hi all, it's been 2 months i start to use Rewasd playing Warzone 2, i found out my perfect config and now i fell it really great. I works really good !!
Recently i started to work on "no recoil" control by using Combo on Mouse1 trigger botton and i've got some question:
1) I've seen a video where a guy uggest to use "relative deflection" to simulate stick going down and it works good. I set it to -8% and is ok. But which is the difference from realtive and absolute deflection ?
2) in Warzone 2 the guns have different recoil between each other. For example with -8% relative deflection is good for mp5 lachman sub but not for ISO45. Or it is decent for Kastov762 but not for TaqV bucause a a certain point the gun start going down. Is there a way to config the deflection to get it adjusting to the gun i'm using ?
3) For some guns negative deflection works but for other guns it need also to control "horizontal" recoil.. Is there a way to put it in "combo" settings ?
thanks in advance.
thanks in advance.
