I previously used version 5.8 with no problems. After upgrading to 6.7.1 I get the following:
- Controller Connects, showing full battery
- After 10s, controller disconnects
- After a few seconds, controller reconnects with low battery icon and critical battery warning.
- After a few more seconds, controller disconnects
- 2-4 repeat indefinitely
- Changing the batteries
- Unpair/re-pair the controller
- Uninstall/reinstall ReWASD
- Settings/General -> Clear data
- Change ReWASD preferences: LED off, tray icon OFF
- Update .NET
- Launch Steam, disable XBox Controller support, quit Steam
