Disable ReWasd for certain games
  • Disable ReWasd for certain games
    I was wondering if it was possible to disable rewasd when certain .exe is launched?
    I currently use a xbox series controller emulated as a dualshock 4, but for some games this break the controller keybind (Skyrim for exemple)
    I was wondering if there's a way to turn off rewasd when the game is launched? Instead of having to manually disable/enable it;
    Thanks for the help.
    Unfortunately no. In reWASD, it is only possible to apply the config when entering the application using the Autodetect feature.
    You can try to use Autodetect and apply the config with the desired virtual controller without mapping.
      It seems I was able to solve this then
      Made ps4 controller profil for games needed
      Made a second profil and applied it, it seems it is now the default one and it works now
      I'm able to play Spiderman with PlayStation button, meanwhile in Skyrim Rewasd switch to the default unmapped config and it appears to works this way.
      Thanks again for the help strokel
