hello,
is it possible to map a key, so that it cannot be pressed longer than a specific time ? Like right now i can, for example, only map "X" to be pressed for 150ms, but it always uses 150ms, how would i do it, if i want 150ms max and never exceeds it, but it is pressed shorter if i dont hold it for 150ms ? basicall it never exceeds given value ?
thx 4 help
thx 4 help
