Hi , so i noticed this increasingly lately , not sure if it because of steam controller support or game controller support. In this case it is resident evil 3. I've had this before and got it to work before , but cant remember what i did. I use mouse with right hand and controller with left hand , so with the left stick mapped to WASD , i don't have to lean over the keyboard holding WASD on there. I just push the stick forward and turn with the mouse as i go. So when i stop pushing the stick forward , i can then turn the camera , and push stick forward again. But then it's move , turn , move , turn , etc......Where i want to be able to push the left stick forwards and just turn with the mouse as i go at the same time. If i do use the keyboard WASD keys with the mouse , then it works normally . Wondering if anyone has run into this , or knows a workaround. thanks
Right stick on Xbox mapped to WASD , mouse does not turn camera when i move forward
If you want to control your game with mouse and keyboard inputs:- Create a new profile/config.
- Enable the [Mute all] option of the [Magic Wand] menu.
- Remap your controller to the corresponding mouse and keyboard inputs.
- Optional: select your physical mouse and keyboard at [Preferences > Input devices].
- Make sure the [Advanced Mapping] feature is activated.
- Group up your mouse and controller.
- Remap mouse buttons to corresponding controller inputs.
