Hi there,
I use Asus Rog Ally and I play Max Payne using the downloaded controller configuration, it works well.
I also want to play Far Cry 1, I have already downloaded the controller config.
My question is where and how to save the new controller config? And how to play each game with the correct config?
I'm not a technical guy so please give me a simple answer!
Thanks!
Thanks!
