PS5 with Rewasd without PS Remote Play
  • PS5 with Rewasd without PS Remote Play
    I’m an experienced Rewasd user and huge fan.
    i was wondering if there’s a way to use my ps5 with Rewasd and WITHOUT going through ps remote play?
    Ive been successful using ps remote but my connection is horrible and disconnect/input lag a lot and I want to avoid it.
    Please let me know.
    Thanks
    You can emulate an external DS4 virtual controller and try connecting it directly to the console via Bluetooth or an ESP32 bluetooth adapter.
      Hey Man, only works for ps4 controller. I cannot play ps5 games. Thanks for the advice.
        As far as I know, some PS5 games can be played using a DS4 controller.
        I think it's worth a try.​
          yep, nay works for some. Sadly, the game I want to play (CoD) says doesn’t support DS4 controller 🥲
            DS4 does not work. Do you have any other suggestions?
              Where exactly DS4 doesn't work? What did you want to achieve with reWASD?
