I was wondering if it was possible to mute a toggle button that is running by switching to another shift layer or pressing another key. For example. If I had a toggle set to X on my control pad on the main layer. When my toggle is on, X would be repeated. Is there a way to temporarily turn off that toggle when I switch to another layer, and then turn the toggle back on when Ive let go of the layer switch button and return to the Main layer? I've tried to make this work, but even after I mute and do not inherit the x button on the shift layer 1, the toggle still runs.
-Thank you
-Thank you
