New Radial menu additional advanced feature??
  • New Radial menu additional advanced feature??
    OK I found the radial but it says it's demo only as it's an advanced feature. I have the complete version of ReWASD?? (it wouldn't allow me to update my other post)
    Hi. If you have all the features except the Radial Menu, then you don’t need to pay for it.
    Click on the "Refresh the activation status" button in the "License" section. An offer will appear, by clicking on which you can buy Radial Menu for $0.
      I switched to the radial menu section and refreshed and it says it cost $7.00. Can you check my license?
        I originally ordered Advanced mapping for $9.00 then later upgraded to Full Pack for $9.00.
          I assume you emailed us and received an answer to your questions. Is this true?
