Choosing key to modify doesn't automatically work after latest update?
  • Choosing key to modify doesn't automatically work after latest update?
    Hello when trying to lets say make some macro on E key on keyboard before the update i could just press E and it would choose it automatically but after the update i does not , I need to manually find them in list ... is it a known bug or is it on my end only , can someone please check? Screenshot just for reference of what i mean. Also everything else works normally just a minor inconvenience.Click image for larger version
    Buttons are hooked only when remap is disabled. This is made by design.
    If remap is turned off and the buttons still do not hook, I would ask you to record a video of what is happening in the full application window.
    Thanks in advance.​
      Hey thank you for quick reply , i tested it and you are right works perfectly fine with remap OFF , i guess i got confused and i was doing it all the time with remap off . Sorry for bothering , Have a Great day
