New here. I'm considering buying reWASD (at least the controller configuration part of it) and would like to know if this will enable right stick x axis analog movement to be converted to right stick rotational (full circle) analog movement. If this is possible, I'm definitely signing up! Thanks for any help...
Can u convert rt stick x axis movement to rt stick rotational (full circle) movement?
Unfortunately, there is no such option in reWASD. However, you can try to assign the combo which includes the stick moves​ to the stick zones
I'm not sure that it will be suitable for you, it's worth a shot, though.
