App won't stay open. It goes to system tray. I try to open it again in the system tray and 2 things happen. 1) it either shows up and disappears right away and back to the system tray or 2) if i click a profile it disappears to the system tray again
Rewasd will not stay open
Please check for errors in Event Viewer by following the steps below:
1. Press the Windows button, type [Event Viewer], and press Enter.
4. Once you find one or multiple events, please right-click and "Save selected events..." on every one of them, and DM the file(s) to me.​
