Heyo all, so i'm currently playing fighting games and i've been trying to set up ReWASD with move inputs that are detailed "must be hit at the same time/simultaneously" or "attack must connect at the same time within the same frame"
However, for the life of me I can't seem to set it up to have the commands hit at the same time. Ex: Having to do a move that requires you to hit down+forward+triangle at the same exact time, but I can't get the move to come out just to get it to record. Is there a way to do it manually? I tried to use key combo by setting up directions and buttons manually through there, however they are almost never accurate. Couldn't get it to work with Shortcut mode either.
Basically I'm trying to set it up manually without having to record for moves that require inputs to be hit at the same time/just frames. Appreciate the time!
