Phsyical Controller + Virtual Controller not grouping
  • Phsyical Controller + Virtual Controller not grouping
    HI, I have an issue that I cant wrap my head around.
    I made a app that creates a virtual controller with vjoy and vigem, now in reWASD it picks up as a xbox 360 controller.
    Im trying to group it with a physical controller, when I test it on gamepad tester it picks up as 2 separate players
    reWASD only works with physical input, so it's not surprising that your virtual controller didn't work in that case.
    Also, reWASD itself conflicts with a Vigembus driver, so I don't recommend using both of them simultaneously.​
      It works perfectly using virtual controller plus the Vigembus x360 virtual controller to group the 2, only physical controller seams to have this issue
        Even just having this driver on the PC might be a reason for the proper operation of reWASD
        Unfortunately, there are no any guarantees that your setup will work
          Sunshine requires ViGEM for gampad support. Is there a workaround for this?
            What is "Sunshine"?
              It's a server for Moonlight, the open source continuation for Nvidia's Gamestream client the Shield used. Moonlight client is available on, uhh... Everything that isn't a console?
              Moonlight allows you to play your PC games remotely on almost any device.
              Self-hosted game stream host for Moonlight. Contribute to SunshineStream/Sunshine development by creating an account on GitHub.
