Aim assist not working in The Finals
  • Aim assist not working in The Finals
    I'm a new user to reWASD and I was attempting to use an xbox controller config on M+K for aim assist. I used one of the community configs called The Finals M+K = Controllr Aim Assist [V0.1].
    I've used others and it seems for my keyboard, I have no issues when I apply to Slot 1 and launch the game. Although, when attempting to use my mouse, there is no mouse tracking or aim assist in the practice arena. Here is my configuration below. Could anyone help me figure out what i'm doing wrong? Thanks!
ID:	240893 Click image for larger version
    reWASD does not provide aim assist. It is provided by games for controller players only.
    Make sure to test if reWASD remaps your mouse and keyboard to a virtual controller at the [Gamepad Tester] site first, and don't forget to lock the mouse pointer while testing and playing the game (in most config that would be the [Home] or [LWin] key).
    If your mouse pointer doesn't get locked after applying the config, follow the instructions in case #24 here.
      But if we can remap the mouse and keyboard to emulate a controller aim assist should work yes?
        Aim assist is an in-game feature. The game provides AA when it detects that the player uses the controller only.If for some reason the system recognizes the virtual controller but there is no AA, then it's a game side problem
        Please ensure that you don't have a double input and you set up the controller as the input device.
          Yeah, I ran into the same issue with aim assist not kicking in properly in The Finals. At first, I thought it was my config or stick sensitivity, but turns out the game handles input a bit differently. What helped me was tweaking the response curve and making sure reWASD was emulating the right type of controller—some games seem to prefer Xbox input over DualShock. Might be worth checking your mappings and testing a different profile just to see if anything changes.
