MW3: when alt tabbing and returning, I lose my virtual controller
  • MW3: when alt tabbing and returning, I lose my virtual controller
    I've finally tweaked my MW3 rewasd settings to play as vanilla as possible with this virtual controller. I tend to use my windows button to alt tab almost all the time between games. My game exe is in focus so that disables the profile while on my desktop. Frequently though I will re-enter the game, which re-enables the focus for the game exe, and then the game asks for keyboard and mouse because the virtual controller is no longer recognized or connected. Is this normal behavior?
    I`m not completely sure about that.
    But I can suggest you 2 options:
    1. You can use manual apply instead of Autodetect.
    2. You can try to turn off that checkbox:
      option 2 has been working great so far, thanks for the suggestion.
