Mouse unresponsive as a controller in MW3 after logging and buying the full package
  • Mouse unresponsive as a controller in MW3 after logging and buying the full package
    Good Morning All
    Ive gone through everybody elses topic and I have tried all of the possible fixes
    I downloaded the trial and everything worked perfectly
    I then bought he full package and logged off
    I have since tried to use theprog but the mouse doesnt do anything ingame anymore
    I have attached the following screenies
    The grouping showing my keyboard as a keyboard and my mouse as a mouse
    My mouese works as a cotroller on the gamepad tester
    My mouse works as a controller on joy.col
    My aiming deivce is set to conroller ingameI have tried reinstalling everything, I have tried enabling the emulation before getting into game and toggling when I am in game
    My physical controller is not plugged in
    There must be something simple that I am missing as everything was working beofre I logged off and bought the full package
    Hope spmeone can shed some light
    Thanks for reading
ID:	241174 Click image for larger version
ID:	241175 Click image for larger version
ID:	241176 Click image for larger version
    There is no difference between the Full Pack version of the license and the trial period. Also, nothing could change after activating the license.
    You provided screenshots taken during the trial period. Please send current screenshots after activating the license.
      Hi Strokel
      Here you go, Nothing has changed regarding how it looks
ID:	241189 Click image for larger version
ID:	241190 Click image for larger version
      Thanks
        it is detected it no longer works call of duty modern warfare 3
          JaKKo reWASD doesn't show the [missing features] line, so everything should work the same way.
          However, your screenshot shows a connected controller, which is probably being used by the game instead. Either add it to the group with your mouse and keyboard or disconnect it before starting the game.
            Thanks for yor help but it would appear during my first game logging off and my second game ricochet updated and now rewasd is blacklisted, hence all the other related posts that are appearing now. Guess me and FPS are over, well played arthritis well played
