Remote play mapping doesn't work
  • Remote play mapping doesn't work
    I have reinstalled rewasd on my new computer using the latest version. But I have some issues.
    I am trying to map the default PS Remote play config but it doesn't seem to work. My device (keyboard) is detected, and I can apply the configuration (I have the message on the bottom right corner of my screen saying that the mapping is ON).
    Any idea on what I should do ?
    Thank in advance
    Please send a screenshot of the full reWASD window with your configuration on it
      Here is the screenshot :
        Open Virtual controller settings and check if the PS Remote box is checked
          Thanks a lot, that was it !
          Have a good day
