Hi , just wondering , can reWASD be set up so your controller is seen as a keyboard?
Controller being seen as a keyboard?
reWASD can remap any supported device to a mouse, keyboard, or controller input.
While it is possible to replace a physical controller in the system with a virtual one, reWASD cannot yet hide a specific controller.
We suggest you [Mute] the native controller inputs so that only remapped keyboard input will be visible to the system.
I'm afraid I do not understand your situation.
If you are remapping the controller to keyboard inputs to use it together with a mouse, you are required to have the [Advanced Mapping] feature activated and have to [Mute] all controller inputs so that the game would see only the remapped keyboard ones.
Otherwise, the game might switch to the "controller only" scheme and will ignore any inputs from your mouse and keyboard, which seems to be happening in your case.
when i clicked on " activate" , under advanced mappings it gives me a short description and a " learn more " link , but if i click that link , it takes me to the site and says buy now advanced mapping, there is also a "download" button there , but i think it's activated. On the site where it is bought it shows todays payment , but doesn't say what its for.
Hi. All functionality of your license is displayed in the license section in the reWASD app and also under the serial number in your personal account.
If you have any further questions about your license or payments, please contact us by email at [help@rewasd.com] using the email address you provided at the time of purchase.
