Bluetooth two pc method not working.
  • Bluetooth two pc method not working.
    hello ,
    I am using 2 pc method to Use Virutal DS4 and DS4Windows .
    In the pasted it worked great .
    now when I try to load the config is say is connecting but stay in "Connecting" and nothing .
    I try uninstall rewasd , Uninstall the adapter and reinstall .
ID:	241522 Click image for larger version
ID:	241521Click image for larger version
ID:	241523Click image for larger version
    Please check whether your computers connect correctly to each other via Bluetooth without reWASD.
    Also, please install the latest version of reWASD from our official website.
      Hi ,
      i uodate my rewasd , and yes my bluetooth work without rewasd .
      you and sug ?
        Please change the virtual controller to another one and check if it connects.
