Any way to macro something that alternates between two other macros or buttons?
  • Any way to macro something that alternates between two other macros or buttons?
    I use rewasd with my Xbox controller for pc gaming, absolutely love it. One thing I cannot figure out is how to create a macro to alternate between two things, for example:
    - a macro that alternates between pressing X then Y then X then Y and so on, so you're always pressing both one after the other
    - and to build on that, a macro that alternates between a button and another macro, so say macro 2 = X then macro 1 then X then macro 1 and so on.
    Basically, I am playing diablo 4 and I created a macro to use my main damage skill and all my buffs in one button, so it just uses buffs on cooldown. And I have a secondary skill that I need to use in alternation with the primary skill, so one after the other, over and over (while still using buffs on cooldown). Any way to do this? Thanks!
    A Combo with Break nodes can achieve that. Check this article for details.​
