I've downloaded a mapping available from the Community macros, but said combo macro as a "j" key in it, which I would like to replace to "k" key. I haven't figured it out myself, apologies is this is an easy solution
How do we change keys inside an imported Combo?
In the combo editor it is possible to select combo nodes in order to delete and move them.
Delete the "j" button node, then add a "k" button node from the combo editor toolbar and paste it in place of the "j" button.​
