Gulikit kk3 max gyroscope is strange
  • Gulikit kk3 max gyroscope is strange
    I set Gulikit kk3 max controller "Switch mode" so reWASD recognized it as a switch procon.
    And I mapped gyroscope And I mapped the gyroscope to mouse moving.
    However, when I use gyro, horizontal movement is very slow, and left and right movement are reversed. The issue of left and right can be solved by reversing mapping, but the slow movement does not change even if the sensitivity is adjusted.
    How can I resolve this? Or should I wait reWASD update?
    Try to recalibrate your gyro.
    If this does not help, check if this issue persists without reWASD.
      Oh, I resolved. It's the problem of option's Yaw or Roll. My reWASD's option is Roll, but I use it by Yaw. I changed the option and now it moves rightly.
      Thanks!
