dot .net problem. win-11 install error
  • dot .net problem. win-11 install error
    Hello, I have been using Rewasd for a long time without any problems. When I try to install the rewasd latest update. asked me to install the net. Even though I have installed the latest version of .net many times, I cannot get past the error in the picture on my rewasd installation page.Can you help with this?;
    This message is shown if our service failed to install. That usually happens due to 3rd party software interference, like anti-virus or security software. Trying to install reWASD with those temporarily disabled should solve this issue.
    We also recommend checking the system file's integrity, running the SFC, etc.
    Manually download and install these two packages: ASP.NET Core 7.0 Runtime and .NET 7.0 Desktop Runtime.
    In some cases, corrupt system access rights or missing/disabled system services might be a reason. This case would require reinstallation of Windows.​
      it works. thanks
        You're welcome.
