PlayStation remote play touchscreen swiping help!
  • PlayStation remote play touchscreen swiping help!
    To start off I have only installed reWASD recently so apologies if this is a dumb question or anything.
    i wanted to map the touchpad swipes somewhere else on my controller so it would be easier/faster e.g a joystick or dpad. I managed to do that however it is really unresponsive , slow and doesn’t really work.
    i was hoping if anyone knew if there is a way for the swiping to be smoothly emulated onto my PlayStation controller and if possible make it so I don’t have to keep pushing the joystick/button for it to swipe and instead be automatic so I can hold it in one direction and it will keep moving that way.
    thanks in advance!
    Maybe adding Turbo to your mapping will help you resolve your issue?:
