Whenever I boot up Halo Infinite using a MnK (making the game think im using controller though) I got TERRIBLE frame rate drops. I usually get 160 FPS, when i activate reWASD my frames tank down to 40 FPS. Am i missing something here?
Frame rate drops when using
Most likely, you don't have mappings Muted in your config, which leads to Double Input, resulting in constant change of in-game control scheme that usually produces lags. So, make sure to Mute every mapping in your config, and set up a key that will allow you to use your mouse as usual when you need it.
Check linked articles for details.
