I'm playing snowrunner and I've been trying to implement a mouse steering and a mouse throttling by mapping mouse movement to the left stick. The problem is that I have to keep the mouse moving to keep turning and throttling. For example, if I wanna just throttle up, I need to keep moving my mouse up. Is there anyway I can keep the stick hold on a position without having to move the mouse continuously?
Mouse to left stick emulation
Change the mapping type to [Radial Menu] mode. The option can be found in advanced mouse settings, once you remap it to the right stick.
Note: The Advanced Mapping feature is required for this option to work.
