reWASD first startup crash on unraid virtual machine
  • reWASD first startup crash on unraid virtual machine
    I used unraid to create a win10 VM and everything is running fine with the VM. I can install reWASD normally, but after rebooting and opening the main screen of reWASD it will report an error, and I can only choose to restart reWASD or close it. After restarting reWASD, the error remains.
    How can I set up unraid VM to support reWASD?
    The error report is shown in the picture.​
    Your VM probably does not report the hardware information properly. reWASD works on virtual machines that provide motherboard information. I suggest you try another VM.
      I think your judgment is right ,vmware works. I want to create a cloud gaming console, so I'm still trying unraid VMs.
