I've been using reWASD for a years. Excellent program. However, recently after the latest update when the program launches it crashes. I have tried everything I can to fix it. I have clean reinstalled multiple times, triple checked firewall settings, made sure nothing is blocked in my antivirus. I even disabled my antivirus fully. The only solution I have found is to keep manually relaunching reWASD as administrator until it does not crash. I have no idea what is going on. Any help would be appreciated. Here are the crash logs from Event Viewer:
- <System>
<Provider Name="Application Error" Guid="{a0e9b465-b939-57d7-b27d-95d8e925ff57}" />
<EventID>1000</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2024-04-12T00:22:12.0325244Z" />
<EventRecordID>123665</EventRecordID>
<Correlation />
<Execution ProcessID="13668" ThreadID="13672" />
<Channel>Application</Channel>
<Computer>Workstation</Computer>
<Security UserID="S-1-5-21-579793102-2353825429-1028579828-1001" />
</System>
- <EventData>
<Data Name="AppName">reWASDEngine.exe</Data>
<Data Name="AppVersion">7.2.0.8995</Data>
<Data Name="AppTimeStamp">65cd0000</Data>
<Data Name="ModuleName">KERNELBASE.dll</Data>
<Data Name="ModuleVersion">10.0.22621.3430</Data>
<Data Name="ModuleTimeStamp">72facb1a</Data>
<Data Name="ExceptionCode">e0434352</Data>
<Data Name="FaultingOffset">001496e2</Data>
<Data Name="ProcessId">0x1fe0</Data>
<Data Name="ProcessCreationTime">0x1da8c6f75ddba85</Data>
<Data Name="AppPath">C:\Program Files\reWASD\reWASDEngine.exe</Data>
<Data Name="ModulePath">C:\Windows\System32\KERNELBASE.dll</Data>
<Data Name="IntegratorReportId">cb08e8ce-6ff3-427c-a698-538b2b6a298d</Data>
<Data Name="PackageFullName" />
<Data Name="PackageRelativeAppId" />
</EventData>
</Event>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
- <System>
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2024-04-12T00:22:11.9488343Z" />
<EventRecordID>123664</EventRecordID>
<Correlation />
<Execution ProcessID="8160" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data>Application: reWASDEngine.exe CoreCLR Version: 8.0.424.16909 .NET Version: 8.0.4 Description: The process was terminated due to an unhandled exception. Exception Info: System.InvalidOperationException: Collection was modified; enumeration operation may not execute. at System.Collections.Generic.List`1.ForEach(Action`1 action) at DiscSoft.NET.Base.Localization.LanguageChangedEven tManager.OnLanguageChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at DiscSoft.NET.Base.Localization.TranslationManager. OnLanguageChanged() at reWASDEngine.MainWindowViewModel.OnPreferencesChan ged(Object obj) at reWASDEngine.MainWindowViewModel..ctor() at reWASDEngine.MainWindow.OnLoaded(Object s, RoutedEventArgs e) at System.Windows.RoutedEventHandlerInfo.InvokeHandle r(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Objec t source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(Dependency Object sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArg s e) at System.Windows.BroadcastEventHelper.BroadcastEvent (DependencyObject root, RoutedEvent routedEvent) at System.Windows.BroadcastEventHelper.BroadcastLoade dEvent(Object root) at System.Windows.Media.MediaContext.FireLoadedPendin gCallbacks() at System.Windows.Media.MediaContext.FireInvokeOnRend erCallbacks() at System.Windows.Media.MediaContext.RenderMessageHan dlerCore(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.RenderMessageHan dler(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.Resize(IComposit ionTarget resizedCompositionTarget) at System.Windows.Interop.HwndTarget.OnResize() at System.Windows.Interop.HwndTarget.HandleMessage(Wi ndowMessage msg, IntPtr wparam, IntPtr lparam) at System.Windows.Interop.HwndSource.HwndTargetFilter Message(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation( Object o) at System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatch When(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeIm pl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)</Data>
</EventData>
</Event>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
<Security />
</System>
- <EventData>
</EventData>
</Event>
