Never had this problem before. But recently one of my HDD failed, so I had to reinstall Windows 11. It is a clean install.
Used reWASD720-9014.exe for installing 7.2 reWASD (revoke license from your website and apply license to new install). Installed it on D: drive with no problem. Restarted - still no problem.
Then open reWASD and it gave me error (see attached screenshot). Notice that for some reason on top-right corner it says "(Unverified License)".
If I restart reWASD using "Restart reWASD" button (see attached picture) ... then everything works fine and there is no issue with license.
But if close error screen without restarting reWASD ... and try to launce reWASD using reWASD.exe or reWASDEngine.exe (both normally and in administrative mode) - gives same error ... until i press "Restart reWASD" button on error screen.​
