Like others, I had to update reWASD today otherwise it wouldn't read my license key, so I did. However, after that I was not able to connect to my Switch anymore, it was fine on previous versions. I cleared all user data, setup the bluetooth adapter and tried to setup my switch from the start. After it says that it's applying my config, a new connecting window pops up, the same one. It is an infinite loop and cancelling the new window will not let the previous window go through. Here's a video:
Unable to connect to switch after forced update
Please send us the file with system information. It doesn’t include any personal data but shows active processes, installed apps and drivers.
3. Go to File -> Save
4. Send us the *.nfo file you get
Alright, here you go. File exceeds 2MB so I put it up on Dropbox:Originally Posted by strokel View PostHey there!
For the record, my bluetooth adapter is a PCIE card from ASUS, the chip itself is Intel AX200 (with the WiFi component currently disabled as I am using Ethernet)
