something prevents rewasd background agent from normal functioning
  • something prevents rewasd background agent from normal functioning
    With the last version, I get the error in the title.
    I see this problem on reddit :
    and applied the different solution but no luck.
    I tested :
    - firewall off
    - antivirus off
    - start as admin
    - uninstall (full) then reinstall
    - msi afterburner and reva tuner uninstalled.
    Note that the service is starting (my controllers are mapped). The tray bar is shown but with a grey badge (seems it was green before). So rewasd is "working" but I cannot edit my config
    I reinstalled the 6.7 version and it was working, until I restarted and that it tolds me that the drivers are not compliant and forced me to update to the last version.
    Thanks for your help
    Try installing these two components manually: ASP.NET Core 8.0 Runtime and .NET Desktop Runtime 8.0.4 х86​
