When Will The Turtle Beach Stealth Ultra controller be Added to reWASD?
  • When Will The Turtle Beach Stealth Ultra controller be Added to reWASD?
    Windows 11
    Turtle Beach Stealth Ultra Controller
    I downloaded the reWASD App and installed it, rebooted my computer, and connected my controller.
    The controller is recognized in reWASD as a Xbox Series X | S controller.
    I clicked on Add Config
    All the Front buttons work and can be remapped.
    But when I go to the back buttons option, there are no buttons indicated. And when I click the paddle buttons P1 P2 P3 P4, the app does not recognize them.
    I realize the Stealth Ultra is not listed as supported device. But in every aspect of the TB Stealth it functions as an Xbox Elite 2 controller, except the rear P1 - P4 buttons are not recognized.
    Any Idea how to remedy this?
    Or when will you add support for the Turtle Beach Stealth Ultra?
    Hello.
    There aren't many controllers whose extra rear buttons report to Windows as separate controls, similar to the Xbox Elite/Elite 2.
    The Turtle Beach Stealth Ultra controller is not one of them, so reWASD detects it as an Xbox Series X | S controller.
    However, you can try this workaround to remap the back buttons.​
      Based on my post above, it is unlikely that paddles will be directly remappable. So if the controller is detected as Xbox Series X | S, then that is the maximum possible support at the moment.
