ReWASD waking PC from sleep
  • ReWASD waking PC from sleep
    My PC wakes up about 2-3 minutes after I put it to sleep. After running "powercfg lastwake​" in CMD, the results are:
    Wake History Count - 1
    Wake History [0]
    Wake Source Count - 1
    Wake Source [0]
    Type: Wake Timer
    Owner: [SERVICE] \Device\HarddiskVolume3\Program Files\reWASD\reWASDService.exe (reWASDService)
    Owner Supplied Reason: ReWASD Macro Timer
    How can I fix this?
    Could you clarify which version of reWASD you are using?
      Latest version. I figured it out though, thanks!
      If anyone comes across this in the future, here's what I did:
      Type "services" in windows search bar and select the first result
      Find the service that is causing the issue. for me it was "Game Controller Mapping Service"
      Right click and select properties
      Change startup type from automatic to manual
        If this happened on the release build, then thanks for the information. It will be useful.
          I just downloaded it yesterday so I assume its release. It's 7.2.0.9014
