Ok, the closest I can find inside reWASD is an option for "half-press", which makes the adaptive triggers on the DualSense become rigid at the halfway point. This is pretty good already but I was wondering if there is any way to make the triggers become rigid at 25% travel instead of halfway. Or maybe an option to set the desired distance yourself.
Note that what I want can already be done using DSX software, however DSX has compatibility issues with reWASD so I don't like using it. However DS4Windows works perfectly with reWASD, but unfortunately does not have those options that DSX offers.
