Hold SHIFT while any left stick button is used
  • Hold SHIFT while any left stick button is used
    In Elden ring I want to sprint automatically whenever I use the left stick. I tried using a combo holding shift+WASD for each of the 4 stick directions, but it is not reliable, sometimes triggers the dodge.
    Is there a way to bind shift to any left stick directions, or another way to achieve this?
    Try to create such a combo in Hold Until Release mode:
    Tests in Viewkeycode show that the system catches the input without any issues. ​​
      ah thanks that works much better.
      Another problem though is that in this game shift is both dodge and sprint. so when I use this shift combo while moving, it interferes / prevents dodging for an (important) split second.
      Is it possible to cancel all other inputs while pressing say the B dodge button mapped to shift?
        In fact, is it possible to release shift in a combo before pressing shift again?​
          If the stick is held at the same time, then no.
