Hello, Can someone explain how to use comunity configs. I am a new user, I want to use comunity config for xDefiant. I found 3 configs. I import them and dont know what to do. How do I run them. It says that they will work automatically when I run the game, but nothing happens.
Comunity configs
First:
- If you are using reWASD for the first time, I suggest starting with this article.
- You can get familiar with all interface elements from this article.
Second, I suggest you apply your config manually and test it here.​
