Pinball FX3 with X-Arcade Tankstick help!
  • Pinball FX3 with X-Arcade Tankstick help!
    I'm new to reWASD I was wondering if I can use it like this. I'm trying to map pinball fx3 to my X-Arcade Tankstick. The Tankstick has 2 players on it. The back/select button is on each side of Tankstick. Like a pinball. Can I map player 1 select on button to right shift. And player 2 select button to L shift button and use it in pinball fx3 ? Ease help can't figure how to do this.
    Unfortunately, this device is not supported in reWASD.
    It should be recognized as an Xbox 360 in X-input mode; therefore, we cannot guarantee that all buttons can be remapped in reWASD.
    If the buttons you mention are displayed correctly and can be remapped in reWASD, then yes. You can check this during the trial period.
