I've been trying to use ReWASD to map my two joy-cons to individual Switch Pro controllers, so that I can use them in some emulators (Ryujinx and others).
In Ryujinx I'm using each Pro controller as Joy-con Left and Joy-con Right for the two players.
It works good, however I have an issue with Joy-con Right, which seems to have a weird behaviour with the gyro.
The thing here is that I believe there's no problem with the joy-con and I have both joy-cons with exactly the same mapping on ReWASD.
However, I'm not sure if ReWASD uses the two gyros independently. Seems like it is messing up a bit with them.
Did anyone experience the same thing? Is it even possible to have ReWASD doing what I'm trying to achieve?
Thanks
Thanks
