Combining Turbo and LongPress
  • #16
    Personally ... if all I needed was turbo on A button and all buttons are taken, then i do turbo A on (double click A) OR do turbo A on shortcut (L2+A)
    and dont tell me L2+A also means something in MK lol
    • #17
      Ahaha! Yes, it does!
      Those shortucts you mentioned... Is this possible to activate them by conditions like press r1 while hold l2? I think push them together will be uncomfortable.
      • #18
        What you describe is Shift Layer ... so you hold L2 shifts to another Shift Layer ... in that new Shift Layer - R1 will do something
        Since L2 is used for something ... one option is assign shift to long press ... and to know when this shift happens - can add combo with rumble
        See attached config ... it implements what i described ... and R1 in new shift layer - just turbo R1
