Mobapad m6
  • Mobapad m6
    Hi there, i was thinking of buying a Mobapad m6 joycon alternative, and i wanted to know if anyone here knows if they are compatible with rewasd, because ive had a lot of compatibility issues with other less well known knock off joycons.
    Thanks!.
    100% guaranteed compatibility has the original joy-con in reWASD. Unfortunately, I can't provide you with additional information as I even don't have feedback regarding this model
      They are all over the place on reddit because they have hall effect sticks that do not drift. I think they are the most famous of the non official joycons.
        Did you ever try these controllers with rewasd?
