Input being interrupted
  • Input being interrupted
    I dont know if this is how reWASD is supposed to work but Im assuming its not, I have my keyboard keys mapped to xbox360/ds4 controls and if i hold down a key, say "W", then release any other keys(doesnt matter if its pressed before or after W), the input for W and any other mapped keys are interrupted until I let go of W. The same thing happens when I move or click with the mouse.
    Please send us the config you are using. Your configs are stored here: C:\Users\Public\Documents\reWASD\Profiles
    We need the correspondent *.rewasd file.​
      This is the config, I tried the gamepad tester from hardwaretester site and it looks like the keys doesnt get interrupted and its more likely the game's fault
        I suppose it's because of double input. Please ensure that all the KBM buttons you use in the game have the same input.
