3 second auto hold
  • 3 second auto hold
    Hello. Can I make a macro for Rewasd such as holding a button automatically for 3 - 4 seconds and then releasing it automatically? That is, when I press the button, a combo that will hold it for 3 seconds for me and then release it after 3 seconds. Thx for help
    Hi.
    Here is an example of a simple combo, in which Circle will be held for 3 seconds:
    You need to put the desired pause (1 sec = 1000ms) between pressing and releasing the key.​
      Hi.
      Thank you my superhero
