I have an issue with mapping key 28 as shown on the Cyborg II picture in the reWASD app. It's a thumb top key on the controller. I tested this key with the Azeron application and that key was reported as pressed and depressed with no issue in the native software. However, when I use reWASD, the assigned key is not working. Is something special should be done to make it work or it's a bug in the reWASD?
Thanks
Thanks
